Change ‘01 sequoia antenna from powered to fixed
Hello everyone. I’m trying to turn my 01 sequoia limited antenna, which is powered, to a fixed base. I assumed I could just buy a fixed base and be done with it. However, I’ve run into a mess of part numbers, discontinued parts, etc and I’m hoping someone more wise in the ways of Toyota can help.
I have made three purchases from people that “swore” their fix would work and they never do. The old fixed antenna base main wire to the head unit is cut so reusing that could prove problematic. It doesn’t seem like the type of wire I can just splice in and be done. I already have a stubby antenna mast I’ll use, I just need a fixed base. Antennas r-us used to sell this but they’re out and haven’t gotten back to me on if they will get more. Any assistance on this is appreciated. Any specific part numbers would be very helpful.
Thank you.
@tlhfirelion
86300-AF020 Antenna Assy, w/hold
Fixed ant Assy.
Was for a tundra.
Ran the part number through Amazon and several reviews state it was used to replace power antenna on 1st gen Sequoia and worked like a charm.
Cheaper elsewhere online but plenty in stock
@tlhfirelion
Fixed ant Assy.
Was for a tundra.
Thanks for that helpful reply. I found it on Amazon so I’ll try and see if that works and report back.
@tlhfirelion
Fixed ant Assy.
Was for a tundra.
Wanted to give an update. I bought the above antenna and didn’t think it would work at first, but it will. It does have a very slight lean to the rear as some of the Amazon reviews stated. Thanks to LandcruisinMy93 for his help!
