Central Locking Failed (2 Viewers)
Oxfordshire
Hi.
As mentioned in the title the central locking on my KDJ95 seems to have given up the ghost. My car never had a button on the fob or whatever but when you unlock either the drivers or passengers door with the key all the other doors would unlock. It stopped doing this a couple days ago and now just the door i unlock with the key unlocks. This is a pain to get in the boot.
Any ideas or experience before i start replacing everything in the fuse box's with "Door" in the name?
Ben.
*Update*
So i tried disconnecting the battery's to reset the system and it didn't work but i did notice that all the doors lock when i reconnect the battery's so the car can tell them to do so, but it seems like it inst telling them too when i unlock the door with the key. Also forgot to mention but the button on the drivers door near the window controls also does nothing.
Also does anyone know a way of unlocking the boot door from inside the car? The key hole on the outside is jammed and cant seem to find a latch or anything from the inside.
Forgot to give additional update. Problem fixed about a week ago after getting locked out of the car while it was running whilst working under the bonnet with only one key. :bang: Was down to corroded contacts on the drivers door control panel for the windows/locks etc. A quick clean up and the issue is now solved.
