I’ve been having a problem over the last month in my 05 GX with 175,000 miles.
It usually happens within the first ten minutes f my 45 minute commute. When I apply the brakes, the power to the stereo and hvac cuts out momentarily. The lights go out and audio cuts out. It doesn’t seem to affect gauge lights or any other electrics.
I have base non-nav, non-RSES, non-third row truck. I did add a from Bluetooth unit about 60,000 miles ago.
I don’t think it’s an alternator or bateery issue and is isolated to the center. Should I be looking at fuses or is there a ground down behind there? it happens even with a gentle tap of the brake pedal not just heavier braking and it’s only as I initially touch the brakes, and power comes back even if I continue to brake.
Has anyone ever encountered this?
