My center differential is leaking from the front side. I can't tell at this point if it is the gasket for the front extension housing or the oil seal.
If it is the oil seal, then I'll have to take it in, I don't have the tools/knowledge/dexterity to take apart and reassemble the front out shaft assembly and reseat seal and snap rings.
Assuming (hoping) it is simply the gasket:
this one https://forum.ih8mud.com/threads/center-diff-transfer-case-leak-at-the-front-need-advice.357847/ but still can't figure it out.
Any input would be appreciated.
- Can the front housing be removed along with the front output shaft assembly while the remainder of the case stays in place? Can I just remove the six bolts and break it open at the gasket?
