Center Console Organizer for Heritage Edition w/o Cooler
Clovis, CA
Does anyone one know of a center console organizer for a Heritage Edition with out the cooler? I've looked on amazon and this forum and cannot find anything. As of now I just have a black hole of space.
Post a pic of the console from above with the lid open. I have this for mine with the cooler, if they have the same opening then it's a solid item and a killer deal for $15.
Mine came with a tray that fits into the larger bottom opening. Did you not get that, or are you asking for something else? I can take a pic if that helps explain what came with mine (it wasn't an option or dealer add-on).
Edit: Took a pic anyway. Here's the tray that came with 2020 HE
Edit #2: I found the part online (Toyota 58806-60080). If you look for it be prepared to be in sticker shock on how much Toyota wants for some plastic.
Thank you for posting this photo... I also received this with my LC. However, I was hoping for something a little more segregated to help organize. I like what was posted above for $15. Anyways, appreciate your response!
This may or may not help you but I reached out to the company who makes these because I’m also looking for a organizer thing for the lower part of that console. I got one of these for my daily but they didn’t make one specifically for it so I got one that was too big and cut to fit. It was a fairly easy process and it turned out perfect. I haven’t ordered for my LC yet because I’m still waiting on the vehicle and they asked for some dimensions and pictures. I expect the same process as before… buy one for a larger console and cut to fit.
Or you could just buy some HDPE and make your own dividers. Anything else is a compromise of accepting what’s available. What are you trying to segregate? Firearms? Tools? Kleenex? No two people are looking for the same solution. HDPE is easy to cut and sand. Comes in black and is solid.
i did this
Made dividers for the center console in my '21 HE. I didn't like the lack of organizing dividers and the slick plastic surfaces where everything slid around and made a racket.
it's essentially a take off of the design of the Trekpak system for Pelican cases. i attached adhesive-backed felt on both sides of a piece of corregated plastic (like stuff used for lawn signs). then cut across the corregations to make panels of the desired height with a series of 'tubes' exposed. i then attached the panels together with bobby pins through the tubes. i also put the felt on the bottom of the top tray and the bottom of the main compartment.
top tray:
main compartment:
