I'm thinking a little ahead as my new wider fenders are fabricated. Our CDN M101 is already set-up with 6x5.5 hubs and is currently running some old 28" Goodyears on FJ60 rims.
I measure 3 1/2" between the bottom of the bumpstop and the top of the spring, but realize that a hard bump could give a bit more travel depending on how much the bumpstop rubber compresses.
There is currently 6 1/2" from the top of the 28" tires to the underside of the fender. So I calculate this gives about 3" of minimum clearance to the fender bottom with the current tires and suspension, depending on compression of the bumpstop.
Eventually, we plan to run 33" BFG MTs on our 80 and do the same on the trailer. This means that the tires will use up most, if not all of the 3" under-fender clearance that the current suspension provides on top of the tire.
So this would be darn close to using all the extra clearance under the fenders in stock configuration with the axle on top of the spring. The wider fenders will be smooth, all new metal from the body to the outside lip, where they will have a 1" angle welded on to stiffen them. There will be nothing to snag underneath where the tire can potentially contact the taller tire.
Has anyone run this particular configuration that has experience? Should I go with ahead and plan on a preemptive spring-over-axle? Or should I just see how it goes, because it's unlikely to be more than minimal contact in any case? I actually prefer to keep the lower center-of-gravity in the stick configuration, given the sidehills we encounter.
I ask, because we head over the passes in Colorado where this is likely to first get really tested. I'd hate to get somewhere where I'd have to make a 250 mile detour or, worse, get stuck with tire damage just to get off the trail. I kind of doubt the worst case scenario, but figured I'd ask...and get some opinions;p
