BMAN said:That don't sound right to me. Let me go do a little checking and I'll get back to ya on this one.
get an antenna that doesn't need a ground. I installed a no ground type on my 80 with the antenna mount bracket and a quick disconnect. IIRC i was getting 1.2 on the SWR.
Just want to tell you guys --
That even thought A*B includes the mount on their bumpers it has to be one of the worst places to mount an antenna..
It will antenna will work but not at it's best.
I may be just anal BUT in the centre of a metal roof is by far the best..
You will get your best RF ground plane in this location.
You will not get your best ground plane on your front or back bumper..
If you do not want to drill a hole in your cruiser roof, stick a roof rack up there.
Mount your antenna in centre..Verify all is grounded - can not be said enough-verify all is grounded.. No rubber feet on the roof rack etc.
You should be striving for a 1.1 : 1 or less match when tuning your antenna.
Once your installation is done.. you can measure the RF signal coming off your truck with a field strength meter. This will tell you which way most of your signal is leaving your vehicle - front - back- sides..etc..
Good luck
Thanks. I'm not trying to reach my dead father in 1959, just keep up with the chit chat on the trail. I'll probably end up with a 3-4' fiberglass antenna on the ARB.
Dual antennas need special feed lines. The shorter you go, the less the performance you'll see. If you don't mind not being able to get very far with the radio, go for a rubber ducky, or even a small whip on the ARB. I'm never saying it's wrong (in fact I have my Ham antenna there :O ), just not optimal.
Plus they need to be 8 feet apart to work correctly.
Also remember that SWR simply measures the amount of match/mismatch in the impendance of the whole system. Simply a low SWR rating does not imply that your effective radiated power (ERP) is good, as it may be significantly diminshed. If you have competing impedance imbalances in the system, it can suck your power, but in aggregate still report a low SWR as they may cancel each other out.
I'm wondering where you guys wheel that a CB antenna on the roof won't get torn off 10' into the trail. I'll probably end up with a 3-4' fiberglass antenna on the ARB.
Are you talking about the dual antenna's needing to be 8 feet apart to work correctly?
