One thing we talked about last meeting was doing a day ride up at Caryville this spring. This would also be a good chance to see if you have everything sorted out on your truck prior to GSMTR. I'll propose 3-28 and 4-11 as a couple of possible Saturdays. Anyone interested in doing this?
Check out YouTube and lookup agoode79 Caryville videos. http://m.youtube.com/channel/UC6o6Uibb0mgtE8RAbXVEPCQ
This will give you an idea Jim.
The sand mines at Caryville. No sure on a date yet. I'll post up when I find out.
There is a way up the other side that is not so technical. It is gravel and dirt road 90% of the way up. Then there is a small section of rock to get onto the sand. It wasn't difficult at all a few years ago. I've made that trek solo a few times. Not sure how it is today though. Could be worth a try for those that can't make the gnarly stuff. Once you're on the sand, it's just a playground. Do what you want.
Rance, let us know if you can do the 11th. If it helps, I'm open on the 12th also. I definitely want to accommodate Vic since that was what sparked the discussion.. giving his 40 a shakedown run prior to GSMTR. Joe, Nik?
