Has any one ever used one as a work shop? If so could you post up some pics? I am looking at a 40x8x8 and just curious if any one has used one before and the pros and cons about them.
BS. I spent 3 years of my life in 20 and 40 foot containers. I regularly devanned, Rolls, Lambergini, Ferrari, Mercedes and every other exotic vehicle you can think of. And we only crashed the Ferrari broadside into the vertical rail road metal once.I use the same size for business storage. It depends on what you want to do with it. A vehicle doesnt fit in them very well. They would be good for a small shop if you are doing small projects. Add electrical and a man door.
What kind of prices have you guys been seeing for 40' containers?
I am shopping for one best price I have found is $1200 & $400 shipping (from Jacksonville FL to big bend area of the gulf coast) highest I have seen was 3k delivered.
I could build a wood shed of about the same size for about the same price but it would not be as strong & secure nor last as long and plus I would have to build it. to have someone build it would be 3x the price,
Hope to add another later and make a shop in between the two
I saw a show where there are companies making homes out of those. they place and stack them at different angles and .....instant home
my dad has two set up 20' apart with one of those steel tube frame buildings welded between them. He uses it as a heavy truck work shop with secure storage in each. We added power vents in each to keep the heat and moisture to a minimum. close the suckers up in a hot day and you could cook stuff inside!
We also cut a man door in the side of each one and used the steel frame industrial doors and welded them in with a drip flashing over the top.
The main reason we went this way as opposed to a real building is they are not classed as perminant. He could not build a large enough perminant structure on his lot.
