carb question......but a good one
City that rhymes with fun
ok.......so im going back to the stock 2bbl carb on my 67, the PO had put some crappy 1 bbl on it. its set up with throttle cable instead of the original linkage. i was wondering if its possible to hook up the same throttle cable to the rebuilt jim c carb. i have the actual linkage in a box, but was wondering how hard it would be to format the throttle cable instead of the actual proper linkage which has been removed :beer:
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
67 had a one barrel from the factory.... ;)
Making a cable linkage would not be that difficult. Modify your peddal for a cable, route it to the carb, and you are good to go...
What engine are you running....stock 67-F?
What intake manifold are you using?
the throttle cable is already on.....yes its the stock F, i have a 2f intake and the spacer already to go just waitin for the carb to arrive. so the cable will work? im stoked bout that as i didnt really feel like puttin all that linkage back on. the PO put a rochester 1 bble on it with some kinda goofy spacer made of wood of all things..........yikes
Kansastitty
The piece of linkage on the carb is different than a rod linkage for the attachment of the cable. I have the part that the cable attaches to, which I will give you, but I am lacking the part that the cable sheath bolts to.
PM me if you need the part and I will send it out.
Ed
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
