Can someone recommend a firewall grommet source?
Dallas
Website
www.octagonmma.com
Wiring harness is done and going back in. Need grommets. Summit's selection was lacking. Any favorites out there? OE still available?
I'd love to know.
I just bought a heater hose grommet near the tranny tunnel for like $5 from the dealer....It is the oval two hole grommet....kinda pleased that it was so readily available.
You bought all the same size?
i think trollhole or someone from S.Carolina had that barn find with tons of oem gaskets.. I wanted all of them. Give em a shot.
I just looked at 180 Piece Harness Grommet Set from Harbor Frieght. They are pretty small in size but I am sure will work. You may need several kits to get all the larger sizes needed. I will be needing some in a month or 2 when I start on my wiring. Great thread. I hope we get some good sorces or even some trading back with each other.
I'm just noticing these grommet holes now that the body is on. Funny how the small details pile up fast........can anyone name the number needed? I just went out and counted 4 or so at the firewall.
Toyota or SOR has all most grommets in stock you have to hunt them down, the boot for the early transfer case linkage is not available but slave cylinder boot works like OEM
Early FJ Grommets available this is what I used on my 1966 project i hope this helps some of the early cruiser heads ;)
I used SOR catalog and part #s it was easer to locate,
Unless you have a part # ready to look up most Toyota parts guys wont take the time to help you for very long at least that is my experience.
you can go here to this link run down Toyota #s If you want
IH8MUD Banner Advertising
three wire harness grommets #184-90B
one choke cable grommets #184-10B
Specter Off-Road-Land Cruiser Parts - Page 184-Wire Harness
one heater hose grommet # 187-10
Specter Off-Road-Land Cruiser Parts - Page 187-Heater-Rear 40 & 45 Series
one Speedometer grommet #180-18B 1968-72
Specter Off-Road-Land Cruiser Parts - Page 180-Speedometer, Gauges & Cables
one#072-25 4WD cable grommet
one#072-11 Transfer shift lever rod no longer available,I use a slave cylinder boot worked good !
Specter Off-Road-Land Cruiser Parts - Page 072-Vacuum Transfer Shift Assembly
one vent tube drain#112-04A
one tube drain#112-04B I used a 7/8" grommet on each hose
Specter Off-Road-Land Cruiser Parts - Page 112-40 & 45 Series Front End Body Parts
Steering box column boot #098-22
Specter Off-Road-Land Cruiser Parts - Page 098-Steering Box
There is a throttle linkage grommet # I did not find
good Luck ......Joe
Joe you are the MAN, damn!
