If a person modified the rotary switch so the voltage path wasn't sequential would the ECU lock either the front or the rear independently?
Anyone done this?
Anyone done this?
That at least confirms the ECU doesn't require the rear confirmation to lock the front.
FWIW @ThreeEyedBandit was going to do just that (rocker switch) but we found a locker ecu sitting around and already had all the wiring harness sitting in the truck so went that route.Thanks for the info everyone. I'm going to attempt to use an ECU in my 40 series. I have a rear 80 e-locker in both the front and rear axles of my 40 and I want to use two rocker switches and the 80 ECU. People tell me there are times in our trails here where front only is very useful.
Yes I could build my own circuit using relays but I kind of want the flashing light which I could use a 555 timer for but I also don't want the extra build project.
If I dial mine from full-off to F&R locked positions, it's not uncommon for the front to lock up 1st, further confirming the rear being actually locked is not a requirement for the front locker to function.
Don't waste your time trying the 80 unit. It will NOT allow you to lock the front without trying to lock the rear at the same time. You could put a switch inline the rear diff lock motor wires to kill the power so it wont move, but then you'll need to remember what 'state' it is in if you want it to lock. Another complicating matter to that is the computer has a time out timer, if it doesn't get a 'motor has moved' switch input back from the diff it will kill the power to the motor til you unlock and retry...
Build your own circuit, it is easy. It is very useful to be able to lock one end independently of the other, which the factory computer will not let you do.
If they are the wires that are grounded at the diff, then yea. Those are the wires that tell the computer to do wait to blink, or solid when locked. Can't remember the pin locationsThat makes sense. Thinking about it further I think the pins 2 and 9 back to the ECU just provide the blinking function.
It's what I used for my air-locker ECU, nice to have the factory look and feel. I can share the design if you're interested....but I kind of want the flashing light which I could use a 555 timer for...
Lets your rear end "float" around while the front pulls you up and over.Okay, sort of off topic, but what does locking the front only get you? When would I want to do such a thing? I have seen a couple topics on it so I'm probably due for a schooling.
