OK - I have traced my FI problem to a bad signal generator in my distributor - I think.
According to my manual, "if the ECU does not recieve ignition reference pulses from the electronic ignition system, the fuel pump will be shut off after 2-3 seconds.
I am going to put the fuel gauge on tonight and check the time the fuel pump cycles, but that is essentially what my engine will do - shut off after 2-3 seconds if it decides to kick.
I posted a thread last week - "Fuel Injection System Issue - Won't Start" - there is a description of my issues, sorry, it's a long thread.
Anyway - I have fuel pressure (46psi), ignition, air. Am getting a 51 code on my ECU, which corresponds to either no throttle position signal, gear selector, or air conditioning signal to the ECU. I checked the TPS (ohmed it out according to manual) and only one of the measurements was off...could be bad, so I'm trying to find a tps locally that I could just plug in to see if it starts, but I'm thinkin it's something else.
Any experience with troubleshooting this 3FE would be appreciated.
Cheers
Cheers
