I'm scheduled to look at two LCs tomorrow, and they're almost identical.
The key difference is one lacks service records, but has no accident history, while the other has extensive service records, but also what appears to be a significant accident.
I'm interested to hear what folks think. Here are more details on the two trucks -
Similarities
FENDER SUB-ASSY, FR
LINER, FR FENDER, RH
BRACE, FR FENDER TO
MOULDING, FR FENDER,
MOULDING, FR DOOR, O
KNUCKLE SUB-ASSY, ST
ARM ASSY, SUSPENSION
BEARING, TAPERED ROL
MOULDING, RR DOOR, O
MOULDING, QUARTER, O
BRACKET, FR MUDGUARD
PANEL SUB-ASSY, FR D
ABSORBER, SHOCK
HUB SUB-ASSY, FR AXL
GASKET, KNUCKLE SPIN
SEAL, TYPE K OIL
SEAL, TYPE T OIL
END SUB-ASSY, TIE RO
MOULDING, RR DOOR OU
RING, SNAP
GASKET, FLEXIBLE HOS
BRAKE FLUID
DISC, FR
HOSE, FLEXIBLE
BOLT, UNION
WASHER, LOCK
GASKET, FR AXLE OUTE
UNIT SUB-ASSY,
CHECK ASSY, FR DOOR,
REGULATOR SUB-ASSY,
GASKET KIT,POWER STE
ANTIFREEZE GALLON W
FILTER, OIL
GASKET
CONVENTIONAL MOTOR
OIL
USED WHEEL
USED WHEEL
PS FLUID
HI TEMP GRS
BRAKE CLEAN
TIRE VALVE
DRIVEAXLE
REB.PS.RACK
P/S 12.OZ
If you've made it this far, thanks for reading!
What's the better bet? No accident and few service records? Or extensive records and what looks like a serious accident?
Similarities
- Both are 2004
- Same color (Grey).
- Similar mileage (around 130,000)
- Both are one-owner trucks
- Both priced around $17k
- Interior and exterior appear to be in good condition (based on photos)
- One is for sale by owner, and has few service records on Carfax or MyToyota. Owner says he did most of his own service. Timing belt is done. No record of accidents. Garage kept.
- The other is a trade-in at a Lexus dealer, and it has extensive Toyota/Lexus dealer service records on Carfax and MyToyota. Before selling it, dealer is planning to do front/rear brakes, new tires, new valve cover gasket and new rack and pinion. But here's the catch: MyToyota website shows accident repair in 2005, and it looks significant. Here are the parts listed on My Toyota:
FENDER SUB-ASSY, FR
BRACE, FR FENDER TO
ABSORBER, SHOCK
SEAL, TYPE K OIL
SEAL, TYPE T OIL
RING, SNAP
BRAKE FLUID
DISC, FR
HOSE, FLEXIBLE
BOLT, UNION
WASHER, LOCK
UNIT SUB-ASSY,
REGULATOR SUB-ASSY,
ANTIFREEZE GALLON W
FILTER, OIL
GASKET
CONVENTIONAL MOTOR
OIL
USED WHEEL
USED WHEEL
PS FLUID
HI TEMP GRS
BRAKE CLEAN
TIRE VALVE
DRIVEAXLE
REB.PS.RACK
P/S 12.OZ
