C0278, c1223, & c1241
Nevada
Help.
Buttoning up my build and im getting a few codes. I believe 1 is low voltage? And the other 2 are abs related i think with rear drivers side based on searches. I found the hard brake line kinked and rusty so it wasnt from me. Replaced that just now and cleared the codes. Came right back after i pumped the brake pedal a few times along with all the typical lights and a beeping sound.
As far as i can tell the sensor looks fine and so does the wire to the junction with the passenger side line on the axle. One thing that it could be is when i was installing the rear springs i had a lot of tension on the wires before noticing it and bending the bracket down to get clearance.
Is there any way to test those wires and the sensors? I found the wire assembly on rockauto for $71, but i dont want to just throw parts at it.
Thanks in advance.
Test for continuity. Very likely you stretched it inside
Well it appears i may have stretched it inside. So i ordered a replacement from rockauto. So hopefully will have everything complete this weekend.
