Burning Oil?
Twelve miles in.
I pulled one of my valve covers off of my SBC today to take a look and found rust and oil. P.O. said if was a crate motor with less than 500 miles. It runs strong, but I'm suspecting it's burning oil. One mechanic told me if carb is flooding (which it is) the oil could be washing off cylinder walls. I want to go T.B.I. in the future, but undecided about this motor. I'm no mechanic so bear with me.
Condensation........
A natural by-product of combustion in an engine.....This condensation which is acidic water, passes by the rings under compression into the crankcase and mixes with the sulfur, sulfuric acid is created.......
Water sharply increases the corrosive potential of common acids found in our now day motor oil.......
Soooo..... is your ventilation system up to snuff??
500 miles is not enough to pass judgment just yet.......
clean it up, get running right and see what happens......
Thanks for the reply. Ill check out the ventilation system. Should that much oil be there? Does it make sense about the carb. flooding causing a problem with the oil? po said approx. 500 mi. since Ive put about 400 mi. thanks
How often do you drive this vehicle and for how long, if this engine is only running for short periods of time such as going to the store and 4x4 expeditions then your engine may not get up to temp long enough to burn off the condensation that is created inside of the crank case. I would do a very good job at removing the corrosion and add an oil additive to help with this acidity problem, also as stated in the post look at your PCV system to make sure it is hooked up and working properly. Your carburetor problem can cause the thin film of oil on the cylinders to wash off which in turn will cause premature cylinder wear, why not just adjust your carburetor to fix the rich running issue and save your self some money.
Good Luck!
Corey:grinpimp:
Good Luck!
Good info. Im going to get everything adjusted and cleaned this week. hoping that the oil issue is related to the carb. Ill find out. Like I said the motor runs strong. Thanks
Your condensation problem is more than likely due to not driving it much or the PO not driving it much. I would say that your carburetor has little to do with the excessive condensation; an overly rich fuel mixture will cause poor idle, poor MPG's and fouled spark plugs. How often and how long is this engine run on a weekly basis, both now and previous? Look at it this way...Bran new engine...spotless...run occasionally never getting up to operating temps for very long, then shut off and let sit for a week or so. Now the moisture that has collected in the valve covers causes corrosion on the very clean new fresh valve train. You see because this is a somewhat fresh overhaul the metal is still very clean and has not had very much time to allow the oil to create the thin protective film that most engines have due to running for long periods of time at there ideal operating temps. As you use the engine the oil will start to from a very thin protective film over components, this is what keeps cylinders, valve train, rings, crank and so on from rusting when an engine sits. Do you think your engine is completely protected form moisture as it sits the engine bay waiting for you fire it up? Good quality oil, frequent oil changes and using your engine, not abusing, will prevent this from happening, if you do not use the engine very much add an oil additive which will help prevent his from happening. Some good additives are Marvel Mystery Oil and Lucas.
I hope this helps some,
Corey
Not sure of the time frame of the build by the po, but I believe It took quite a while. could be he ran it for short periods and then let it sit. Ive run it both long and short some wheeling ect. up to temp. looks like he good work on the rig, just didnt finish. Glad to hear it looks like a fresh rebuild.
