Bump, ANESTI
Anderson, SC
A, here's the pic...see what I mean?
I just put an OME Heavy Heavy on mine and it is sitting about the same but my springs havenot settled yet. Also it is set up for front winch rear tire carrier which it has niether of yet....
Dave
How many miles are on your lift? I'm in the same boat as Dave; mine haven't settled a bit.
I'm guessing around 600-700 since installation. I've noticed in the last 2 weeks that the front seems to have settled a good bit more. That pic is on an incline so it actually looks a little worse on level ground. I'm hoping a little weight in the rear will help but I'm still probably going to put a longer shackle on the front. I like the way Anesti's and Gehn's 60's sit. Hopefully that along w/ a set of 33's will get me there.
I have maybe 500 on mine in the 3 weeks it has been installed. i did install some 33's. I will take another set of measurements tomorrow on level ground and see if it has settled any. I have a set of rear drawers that weigh a good biti have been thinking about putting in the back of mine to add some weight.
Dave
Has anyone sent pics to the manufacture to see if they have a solution.....could be a normal thing where the rear takes longer to settle out without the weight of an engine to help settle the springs. Just my thoughts
I've been driving it 4-5 days a week for the last couple of weeeks. I did notice a small amount of rake when I installed it, but looked pretty normal (actually good) at the time.
mine never looked like that. the back on mine was sagging alot. when i loaded it up with my dog box and some gear it got worse. especially at take off.
mine looked more stink bug from get go. there is a picture of mine about a week after it was done with the new tires on it in the winter projects thread.
Dave
Go back and check all your nuts and bolts...be sure the ubolts and shackles are tight....a few years ago JP and I made a trip to GA in the 60 and had this death wobble...come to find out the nut on my ubolts had come loose(don't know how it happened) but the pin had come out of the sping pack. And I had not messed with my springs in years. Now I know you don't have death wobble just wanted show that strange things do happen. I'm thinkin that maybe your front shackles aren't tight or maybe the bushings might some how be srewed up. Not sure just tryin to put things out there to double check.
