As a few of you know I recently dusted of my buggy project so I thought I would post a few pics. I have the electrical, sheet metal and belly plate to complete and then it can be torn down to finish weld the chassis I am hoping to have it done mid July.
Some things that I have done recently worth noting was install a set of Inner Air Lock internal bead locks, they were very nice and light compared to other double bead lock options. Changed the mini ARB compressor to a larger unit that I got from Pep boys, I think it was called the tsunami
and was around 70 dollars? I took it apart to have a look around and had to clean up some stuff but what would you expect for $70? It moves quite a bit of air but I did not take the time to convert the numbers given to cfm. It will fill up my 1.5lb air tank from 0 to 120 psi fast. You can see it in the thrid pic below the cutting brakes.
Matt
Matt
