Got some a while back from Ocam Industries and hadn't fitted them up until today when I felt inspired in the Ozzie summer heat.
Nice and well made with 50 mm steel tube formed to make the bars, and a gusset at the bottom of each with two M8 holes.
To attach to the Roo side steps I removed the removable front part of each step assy and the pipe of the Ocam bars slides right on. The mount gussets required drilling new M8 holes in the step supports as the hole spacing is different to the slotted openings that were for bolting on the Roo step extensions.
To attach the front of each brush bar I cut about 25 to 30 mm off each one, and used Elgate Industries T40-40 galvanised fence tees. As these are made to suit a 40 NB pipe (48 mm OD) and the Ocam pipework is 50 mm OD, I used my press to very gently expand the parts of each pair of tees that would go over the brush bars.
Using 100 mm galvanised M12 bolts and suitable washers and nuts, the fence tees then perfectly clamp the front of each brush bar to an outer upright of the original ARB factory accessory bullbar.
I did not use the supplied brackets as they are too big to securely clamp on the ARB bar uprights.
