Bit off more than I could chew, and need to solicit some advice...
Attempting to replace sway arm bushings, and broke off one of the bracket bolts. I (mostly) drilled it out, and tried to extract to no avail. Wondering what my options are at this point. Either drill it out all of the way and retap to a larger diameter? (I believe it is a M8, so up to a M9). Take it to a shop and have some bolt extraction guru take it out. Or just run the bracket with a single bolt.
Again, any advice would be appreciated. Thanks
2000 LC. Located in Front Range CO.
