VinylSeats
I tried to install the conversion kit tonight and ran into a problem:Yes just replacing with another power mast is less expensive, I had done it twice in one year. I was done with doing that.
You can definitely go that route, it is less expensive and easy.
And just a FYI to everyone, a radio antenna tool will not unscrew the retainer ring on the 100 series, it will not fit on the retaining ring because of the shape of the fender, just use needle nose pliers.
I could not get the old antenna to completely come out; it would get very close but not fully eject.
Just to make sure I understand this kit correctly, does the entire old mast come out (telescoping piece and entire white teeth strip)?
If that's the case and I can't get the teeth to completely eject, do I need to get in by the motor by the wheel well and remove it?
