broke grease sert on u joint
Va Beach, Va
Hi,
can anyone give me advice on u joints, what to get and where to get them? I groke the sert fitting on one and figure might as well replace them all while I am at it and get an extra set. Not sure what the best ones to get or where to get them. Should i get ones with or with out grease fittings? Any better than stock? where can i get them?
thanks in advance.
If you can remove the old zerk, remove it, and reinstall a new one. It is probably a M6x1mm thread but you can check it if you can remove it. If not, you can get a new ujoint from the dealer or your favorite parts store. I have found a big difference in quality between OEM / Made in Japan and Made in China ujoints. I will only buy OEM / Made in Japan these days after buying China joints with the zerks in the wrong place. I also never buy ujoints without grease fittings.
x2 if you can remove the old zirk fitting. Use an easy out for the threads left in the u joint. and insert a new fitting.
I use Matsuba u joints. they are a bit beefier. IMHO
