Brexhaust manifold
Delaware
Has anyone installed the premium BRexhaust manifold/converter? I have the common exhuast manifold leak and these BRexhaust units are listed as an upgrade to the stock oem ones. I am trying to find out if the fit is as good as oem. Thanks.
Link?
The part number cross-references with a Bosal. IMO, a better upgrade (if you want to keep the cats) would be Doug Thorley short tube headers. They aren't prone to cracking like the factory log manifolds (with the BRexhaust manifolds are) and will give you a good power boost. Cost should be the same, although labor will be significantly more.
Good luck getting DT's this year
I received a set of LT DT's in April, but ordered them in December. They have been a good upgrade and were worth the wait
