So I picked up a brush guard in great shape, and got a great deal on it. I know about the "damage multiplier", I don't care. I like the look of these.
I found it on Craigslist for $100, without the brackets of course. It is black powdercoat and only has one place to clean up/touch up. It is straight and true.
After hauling it around for a few days, last night I started mocking up and fabbing brackets. Here is the guard sitting on jack stands.
http://marmot.dudeabides.net/galler...tall_phase1/IMG_20130623_185442_204.sized.jpg
Here is my awesome fab shop, my work bench at the back of the garage. Started by using some heavy angle steel to make the brackets that will bolt to the factory recovery point bolts on the frame. The brush guard lines up perfectly on the outside of both frame rails.
Here are the brackets installed. In order to drill big enough holes in the angle steel, I had to use a 3-phase 3-drill process. I used the awl to divot the steel where I want the drill bit to center. Then drill a pilot hole about 1/4" wide with a little drill, followed by my 1/2" power drill with a 1/2" bit, then finally my little variable speed drill with a stepper bit.
Once the brackets were on, I lifted the guard back onto the jack stands to figure out the next step. The sneakers will not be part of the final design
Turns out that I need 6" of clearance between the top chrome strip on the hood/grille fascia, and the top bar of the guard. That will be neat because I will still be able to open my hood! I took some measurements and I think that the guard will tuck in very nicely around the nose of the vehicle. All that is needed is two L-shaped pieces of heavy plate, with a total of 10 more holes to drill.
I sketched the L-brackets on some steel plate that I had, and made them out of a square to reduce the total amount of cuts needed. It takes a long time to cut heavy plate with a small grinder. I kept getting all of the drill shavings and sparks in my sandals, but it was so hot in the garage! I wore my welding apron when grinding so I didn't burn my clothes off, the angle and plate really throw a lot of hot sparks.
I was having fun, I like doing little fab projects. But I must have gotten tired and impatient, because I let the smoke out of my old Harbor Freight grinder less than halfway through cutting the plate.
It was smoking where the wire went in to the handle, so I can probably fix it. But it was getting late so I took a shower and got some tacos. I will probably go get a new grinder today.
Anyways I think this mounting will be as strong or stronger than the OEM brackets. I wrote WAAG, because I think it is a WAAG guard. They said it would take 4 weeks and $150 to get the brackets. The money is kind of steep, but a month is way too long.
I have a project in mind that I am accumulating parts for, I would like to tie the grille guard into the top of the frame as well for more strength. Maybe today or tomorrow I can finish the brackets and paint everything.
