Brakes on my 40 are locking up once the brake pedal is pushed. Stock '76 front discs w/ 4 Runner calipers, Chevy rear disc swap, 80 series MC, early single diaphragm booster.
I completed the brake swap and upgrade over two years ago, been great up until this spring. Now the MC will not release pressure. Pedal was always a little odd, kinda stiff which led me to believe the booster may not of been a good unit (bought used from mud member who assured it was okay
MC pushrod was trimmed and adjusted, no drag when initially installed, no prop valve installed at this point either.
Pulling up on the brake pedal doesn't seem to help, pressure stays for a couple days and then eventually bleeds off. I can't seem to get the booster test trick about listening to idle and whatnot from the FSM to make sense either. Has good vacuum and no discernible leaks.
Thinking the booster must be bad, can the linkage come apart internally and allow the pushrod to "grow"?? Thanks for the help, will probably tear into it tonite and see what I can find.
