I replaced mine with OEM rotors and pads. Having to do over, I think I would go OEM pads, but add the anti-squeal shims (mine were missing) and likely go with Powerstop rotors - they are not that much more and my OEM rotors were warped and causing a shimmy. Both my inner bearings were in need of replacement, not sure if its wear or prior wrench that caused this, but be prepared.
My theory, if they are warped and you have them turned and put them back on, you might still have to replace them?
Best of luck
Best of luck
