brake pad shims, anti rattle spring on tacoma??
ok. here is the story. went to change the brake pads on th 01 tacoma, pulled the wheel off and it looked different than what i was used to. looked on the fsm and saw you have to pull the spring and two pins out etc. according to the fsm there are 4 shims and an anti rattle spring that needs to be replaced too. i called the parts store to ask if those were extra parts i needed to purchase, he said no, it was all on the brake pad, direct oe replacement. there does appear to be a shim fixed to each pad and the wear indicator tab. no anti-rattle spring or is that it.
the replacement pads are car quest premium plus akebono pads. are they a direct swap or what? do i need to re-use the shims and anti-rattle spring that are supposedly already in there? somebody set me straight please.
you reuse the shim, that is all that is reused- put the new pads in, 2 pins and their retainer spring & your done.
