Finally located the source of a slow brake fluid leak in my 1977 FJ40. Leak appears between the master cylinder and the booster. Has anyone had this happen? Not sure how involved it might be to fix.
Good to know. I'll check that right away.Depends on the damage to the MC, a kit might not fix it - the whole unit isn't all that pricy. Second make sure the booster isn't leaking vacuum or it will make cylinder 5 run lean and cause $$$ damage.
I'm assuming the piston seal nearest the booster is the culprit. Is that a fairly common issue?You need to rebuild or replace your master cylinder. It's leaking out the m/c piston into the booster.
