Braided brake line to front caliper instead of hard brake line? Possible?
Holstebro, Denmark
I would love to be able to remove the front brake caliper on my hzj75, without having to remove the hard brakeline every time and having to bleed the brakes after reinstall.
Have anyone tried to replace the last little piece of hard brake line to the caliper from the original to a flexible line?
Is it as easy as getting a line made or it collide with anything or would it get damaged easily?
I do have a spare I could use for length and type of end connections.
Here you go...
Has just recently been discussed. 🙃
I guess you're in denmark :) I used two of these (one on each side) to replace both the existing soft line as well as the hard line so I can remove my calipers without bleeding.
They were a good length. I used a couple of generic brake clip pins from Biltema to hold them in my existing mounts.
