Bolt/screw that hold in the Ignition switch
caladin
Noob, but trying to learn
Pflugerville Tx
Website
bz93.com
My bolt that holds the ignition switch i bought is missing, on my truck
i did a search but failed to find out what the screw is...
Can anyone tell me so i can get a replacement. it's really tiny.
here is a pic if what I'm talking about:
Thanks,
Cal-
93319-13012 is the part # ... Don't know size, but it's prolly a 2 or 3 mm 1.0 pitch. Part # says 12mm long?
It's metric and a Phillips head. No idea on the size but I'll ck my bolt bin and see if I have one ;)
Sent from outer space via my mind
The Answer
M3 12mm long, Phillips pan head machine screw and a washer for same. that's what it took. With whatever the standard pitch is for that...
Cal-
Cal-
Sweet does it work with the key now ???
Oh yeah i Picked up a new plastic shroud for it because the one that was on it, was about to loose all the plastic bits that held the screws on. One screw completely cracked out the other is is sad shape but i glued it back up as a spare. I fire a little black spray paint on a washer and a longer screw and it'll be fine (it the bottom one) if we ever need it.
Even got some spare keys made at lowes, after reading thread i thought it's be hard but they had the Il-33 equivalent, and a 30 or a 31 that fit even better....just like a longer toyota key. Works great.
