Build Blue Bird 67 - Tilda Bogue Service Station
This thing cleaned up nicely. Pulled everything off that needs to go to PowderKeg
Exhaust manifold output studs. One broke. One I can’t budge so it will likely break as well.
Compression is 125 across the board and it spins smooth as silk.
I need to find one of these engines... its Ideally what I would put back in mine.
Still no springs. So pissed. Totally killing my flow.
You act like you're the only one that's pissed. I NEED TO SEE PICTURES OF NOLEN DOING s***. 😆
Table is finished.
I went to SOR fully expecting them to have these early intake gaskets and they don’t. Anyone?
Step one on this thing is to clean it up nicely to see what I’m working with. I got about 1/3 of a Shop Vac of dirt and rodents out of it
Next I pulled the interior out. Hosed it with Zepp orange
Then I took the pressure washer to town on it
OG seatbelts cleaned up nicely as well
Found my bonus and even some .22 shells to prove this was not owned by a communist lefty
Seat belts are on my wanted list. Missed a set a couple weeks ago 😕
Table is finished.
Shows available and in stock at SOR -
Otherwise there is Simon in Oz who makes both the gaskets and insulator which are perfect - FJ25,FJ28, FJ40,FJ43,FJ45,FJ45-V. Asian SD40 Carburetor Insulator set 1958-1969 | eBay - https://www.ebay.com.au/itm/285209791859?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=8k8p4x2PTuG&sssrc=4429486&ssuid=WVDVJxb7T_a&var=&widget_ver=artemis&media=COPY
Table is finished.
Heat riser gasket.
Looks like I was on the wrong page. Thought that was odd. Thanks.
Every time my package ends up in Hutchins, TX. it’s actually lost. Seriously, 3 times this has happened. I think it’s internal code for “where did we lose that package?”…
Hopefully this isn’t the case for you.
Sorry if I missed it, what’s your plan for fuel delivery? Do you have an SD40 carburetor or are you planning something else?
Yeah it has not moved since Wednesday. I took the bull by the horns and found a guy that ordered a kit and won’t need it for a few weeks and grabbed a front and a rear spring.
I’m back in business.
I have had an SD40 at @FJ40Jim for a few weeks. I’m hoping his timing lines up with mine on it all.
Long live carbs!
