Blackstone differential fluid analysis
Did a search in the 100 section, there is nothing on this in the 200 section, guy did change and analysis on transfer case was still factory fill and fluid was still OK after 160k miles. diff's had been done and they recommended to do them again at another 20k. I don't think this is a issue. I'm just doing diff's to get the break in metal out after the first 30k miles.
Here's a VOA of the transfer case fluid from Toyota Transfer Gear Oil 75W VOA | Gear & Transmission Used/Virgin Oil Analysis | Bob Is The Oil Guy. So if you send in your used oil you'll have something to compare it to.
