Bj74 steel brake lines help
San Diego, CA
I have my axle removed and while doing so I am planning to replace the solid brake lines that run along the axle. Does anyone have good info on the types of fittings, flares, and size of tubing that is required.
My caliper is showing 3/16" for the tube. Sorry for the quality of pictures. I will try to take more later
I do not, sorry. I have done brake lines on a British car and they had double flares. Absolutely no connection to your job.
If no one here knows I'd take a line to my mechanic to see if the flare type can be definitely identified.
I used cunifer lines as shown on this website
http://www.fedhillusa.com
It'll be metric. SOR may have the size or quite a few NAPA stores have metric fittings. It is probably easier to take the line to a good parts stor and match one up for size / length and bend it yourself than properly cut and double flare the line - especially if you have not done one before.
Nuts are probably a standard thread but extra meaty.
Incredible price from Amayama!
Getting them pre-bent is a no brainer for 10 bucks. The fittings are metric, I saw the double flare and thought they were imperial. But then I learned that there is a metric double flare.
I buy pre made sections of tubing and bend it to the desired shape.
I use these to bend the brake line into shape. Way better than a tube bender.
http://www.harborfreight.com/tube-bending-pliers-95782.html
