Hi guys,
I have a problem that has been driving me mad over the past few months.
I'm constantly having to adjust the steering wheel as I drive
- there is a lot of play there.
It is especially noticable at higher speeds.
Things I have already done to try to correct this...
1) wheels balanced and aligned (twice) - by reputable mechanics
2) all new tie rod ends
3) both front L+R new bearings
4) adjusted the screw on top of the steering box
5) new steering damper
6) flushed and filled with new power steering fluid
There is also a groan coming from the power steering pump on steering - most noticable at 2000rpm.
There is some play in the u-joint at the firewall but several people have commented that it is not enough to cause the problem.
I've been told it is the box and that I may have knackered it by over-adjusting the screw on top.
There are no leaks.
It seems like the box is the issue - a lot of play in the steering wheel before the wheels turn.
Any advice? I've been quoted $2500 to replace the box and rebuild the pump but before I do this I was wondering if anyone can help?
Myself and a mate are prepared to do it ourselves but not if it's very high tech and/or required specialised equipment.
Thanks!
Grant
- there is a lot of play there.It is especially noticable at higher speeds.
There are no leaks.
Thanks!
Grant
