BJ73 Antenna diameter?
Coquitlam, BC
The one that was originally there snapped off and has been replaced with me shoving a spare antenna I use for my RC controller and it doesn't seem to be working all that great.
So I think it's time I put in something that'll work. I think the original one still has little bits inside the hole.
Does anyone know the diameter of the antenna that I need to buy?
It shouldn't be that hard to take off the fender and pull out the antenna would it?
Im not sure where you are but a 60 series will fit.
Im using a rubber ducky on my 75 series ,works well:D
I'm in BC, Canada. I do see 60s around here but I'm sure their owners won't appreciate me going up to their cars and taking off their antennas :lol:
And Rubber Ducky?? How does that work? :eek:
The Toyota is a standard size ,the same as many other vehicles on the road.
Was yours an electric antennae? I think you can buy the top bit from Toyota.
Otherwise you just pull the whole lot out and buy a new antennae. and plug the old wire into it.
The hole in the fender is about an inch wide so any base will fit.
A rubber ducky is the blue flexible antennea on my bullbar but it will also fit on the fender,its an old CBers term:D
The black rubber ducky cb antennea now sits next to the blue rubber ducky:D
My antennae was the victim of some over-enthusiastic snow clearing recently. It looks to be a pain to get into the fender to change te assembly - does anyone know of an easy way? And, is the assembly specific to RHD or can I get a replacement from Toyota?
thanks for any advice
I've tried to unscrew the entire base but that didn't work at all, either it just doesn't come off or I wasn't doing it properly :lol:
I think you have to turn those 4 notches at the base.
Thanks, Wayne. I guess that means the fender has to come off?
Maybe it will be an aftermarket unit on the offside corner of the bumper for now.
