Looks like that listing is only for the 85 and up style mount.
earl,
Whats wrong with your mounts? If you do have them and the rubber has come loose from the mounting plate there is a thread that explains what one person did to repair them. He did a excelent write up on it in detail and to this day the repair holds.
Link somewhere ? Wich forum ? Tell us more please.
I always be in the same issue .. only the Toyota motor mounts can handle de torque power on my rig .. but not really much time .. thought 1 -2 years ... here in Panamá are pretty expensive around 112 USD ..
I search several times in the internet some poly or heavy duty options without luck ..
Are you saying there are other motor mount manufacturers? Where are your mounts failing? Are you experiencing shearing in the rubber or loss of bonding to metal?
There are plenty of aftermarket mounts if you can find them.
This is the problem here in North America. Toyota is the only place to find 11-84< 3B motor mount…
Why not chain down that side? The rubber will still work to isolate the vibration, however will not lift.
hth's
gb
When I broke the Toyota's always loss bonding to metal .. and the cheapes ones the rubber ..
chain down . ? how . ?
