Hi Crescent Wrench
I read your post on Chevy power then followed you across to your post.
OME springs.
On studying your photos I find the markings on your springs my not be the same as the marking on my OME springs.
This could be chevypower problem.
I fitted front and rear OME springs to my FJ40 1983 and the front springs did not look right . The bumper stops did not look like they would hit the axle under maximum compression .
When all else failed I phoned ARB the makers of OME.
I notice on your photo that the arrow on the spring points forward and one would think that this goes to the front.
ARB told me this is not right with the arrow pointing to the fixed pivot . To check this I am told to measure the distance from the spring centre bolt to the shackle pin. The shorter of the 2 goes to the fixed pivot and in my case so does the arrow.
Both front and rear springs in my case have the arrows pointing to the fixed shackle.
Can you check if this is the case in your installation. If your springs are fitted correctly one of us has there OME marking back to front.
Confusing .
...via IH8MUD app
OME springs.
Confusing .
...via IH8MUD app
