BJ 74 - Service Specs for Fluids
Philippines
Need info on Service specs for fluids for a BJ 74 (13BT). I tried doing a search but most of the info are for the 80 series etc...
TIA!:)
I guess no one has this info hey? Iv been digging around too, no luck..... I guess we'll just have to wait till my shop manuals arrive.
could be that we didn't understand the question
Can anyone please give the fluid recommendations as per factory service manual for a BJ74 (13BT engine) .Same details as below, but they are for an"80".
Fluid Recommendations per the Factory Service Manual
Engine oil
Dry fill 8.0 liters (8.5 US qts, 7.0 Imp. qts)
Drain and refill w/ Oil filter change 7.4 liters (7.8 US qts, 6.5 Imp. qts)
w/o Oil filter change 6.9 liters (7.3 US qts, 6.1 Imp qts)
API grade SH, Energy-Conserving II multigrade
engine oil or ILSAC multigrade engine oil and
recommended viscosity oil, with SAE 5W-30 being
preferred engine oil
Differential oil
Front w/o Differential lock 2.80 liters (2.9 US qts, 2.5 lmp. qts)
w/ Differential lock 2.65 liters (2.8 US qts, 2.3 lmp. qts)
Rear 3.25 liters (3.4 US qts, 2.9 lmp. qts)
Hypoid gear oil API GL-5
Above -18°C (0°F) SAE 90
Below -18°C (0°F) SAE 80W-90 or 80W
Transmission
11.0 liters (11.6 US qts, 9.7 lmp. qts)
1.9 liters (2.0 US qts, 1.7 lmp. qts)
ATF DEXRON®II
Engine coolant:
w/ Front heater 12.5 liters (13.2 US qts, 11.1 lmp. qts)
w/ Front heater and rear heaters 13.4 liters (14.2 US qts, 11.8 lmp. qts)
Ethylene-glycol base
I'll wait! Thanks.
Fluids
engine oil:6.7 liters (5.8 W/O filter) -19mm plug
coolant: 14.2 liters
trans: 4.9 liters -24mm
ft diff: 3.0 liters -24mm
r diff: 2.5 liters -24mm
transfer: 2.2 liters -24mm
pto: 0.5 liters
winch gear case: 0.3 liters
wheel nuts 101 ft/lbs
Fluids
pto: 0.5 liters
What type of oil did you use for transfer case and diffs?
If you are searching on the net, you will do better searching for the components rather than a BJ74. Look for H55f or A442 or 13BT etc. Or search for other 7* series that were produced in much greater numbers and share many components and thus use the same fluids.
And this question has been answered dozens of times on MUD.
From memory Toyota specs a 90w gear oil. I'd put an 80w90 in it and be done
If it's clean oil of close to the correct grade, she's doing better than many other cruisers around the world😂
Manual T-case: API GL4 or GL5 SAE90, non-hypoid.
Automatic: ATF Dexron II (which rare now. No idea whether Dexron III would also work)
Dexron II also goes in the steering servo pump
Diff: API GL5 hypoid SAE 90 (good to -18°C, use SAE 80W-90 below). Caution on rear axle if it is a limited slip. Needs special oil then ( usually same spec extended by 'LS')
