Hi fine folks, just wanted to write to let all know that I phoned the people over at BG Products today to ask about the base ingredients inside the fabulous fuel system cleaners they offer. It turns out that all of their offerings are detergent based, not solvent based! A while ago, we were wondering whether the BG 44K and the BG MI3000 were solvent based and whether or not we would want to replace the oil right after running the stuff through the tank. The chemist told me that the products will not degrade the oil in the way a solvent based product would however whenever any dirt or any deposit is cleaned off engine components, that dirt and deposit will either work its way through the exhaust out of the engine or some of it by blow by will get into the oil. So for that reason, it is prudent to time the treatments prior to oil changes but not because the oil itself is in any way attacked. The chemist also told me that the products will not degrade any fuel system component such as fuel hose, valve stem seals, injector seals etc. In fact, he stated that you could fill your tank with 44K each and every time and the only harm done would be to the wallet! He also stated that the MI3000 and the 44K are the exact same base stocks, just that the MI3000 is less concentrated and is designed to be used between 44K uses.
Just wanted to clarify this for those trying to decide on using BG Products vs. Redline for example; they are all detergent based so whatever flavor you prefer is probably fine, granted the Redline is much less potent, but, it is also much less expensive and as such can be used much more frequently. Hope that helps.
For All!!!
