What's better:
1)
- You raise your LC with AHC by moving the sensors
- You install the little black box that locks the AHC in L, N or H regardless of speed
- You normally drive in L (which could be close to the Normal without the AHC lift and shift it to N or even H when offroading
or
2)
- You don't do the AHC lift by moving the sensors
- Install the black box that locks the AHC
- You normally drive in Normal and lock it in H when offroading (or using your 33" offroad tires..
Wouldn't an LC raised with AHC tweak, have the same shock characteristics in L as an LC without the AHC twrak have in N??
The reason I'm asking is that I did the AHC lift and in Normal with my 285/75/16 Toyo MT, the truck looks and works great!
Issue: When changing to "H", I don't have enough rebound-travel... so H is pretty much useless (although it looks great!
I want the LC to look better with my street-wheel setup (OEM rims and tire size)/not have that big fender gap, so I was thinking about being able locking it in "L" during street driving. But then, I though about reverting back to normal AHC high and drive in N during street-driving and lock it in High during offroading or when having my Toyos on (which I would need to drive at highway speed)...
It really comes down to that the AHC system has a finite range.. you don't get it super high and at the same time retain the super low.. when moving the sensor you move the location of the suspension range... I knew this but realized it more when trying to drive in "H" at Pismo dunes and could feel how the suspension had no rebound-travel left..
Ideas, comments, experience, keep 'em coming!!
1)
or
2)
