Best Mod for under $100
I forget who inspired this, but thank you.
7-round RV to BOTH 7-round and 4-flat.
iO8QHDh-Ssv-OWvAdeMbLKp2GjKIht7DajyHem7Jcx_03wx6wGa22aC1CxG00YKiUIKqEs5A27sfQriwV6PJz_YkMdjttxKvo6SxttVUT6W8aSKCvgIvpbO9_0whssZlrzSP42iZ5GkE_-GzXYwtJEktR1vaFTzQbjv7yOF83OSiwiVC-1BWu6IGWuSNadzmQ9O2ElgMwVuNXSod8tlr0ENOaPwzJ69KnLXqH7zpSTlbQZ5P2UQ-D0_Y3jiL0PCCFh-luUc_qd6Swa6GxRSVkuGTG6DG8RrGQJHXi4FTFKEyzqvkRz0AhIHhzW0DHRmU13_CaC5nozG2b4HxY2_vFEzR5OGUfD_6G2t-M23l86kIsDzc-b9oXYiD201w63V10s7IEIQHRQ8FZGpN9UffdhF9zmQDJpo-Djnx1FKcwiYkPCHzcm0F1gx2kAnweqb_n0h9nRLBLcoXU4FmpZjNKm5oV_97sSI9xXi-Mvdaoad7xQ_PM1fym6lwsGTx_ETGRnBjDA5kNZbMOON8BWNgn2nL1bsyxfmkTOyZN-lb8UtWPox0YzkUxRzFb8ObMZaT3oWitPWhBZwRV4s-fTpKegdcSFF5TEvaOWK5nesKZ_hkeQM9h7533X_tbEX_a6GO=w842-h631-no
Sorry for the delay on answering. I did not break off that tab. There seemed to be no need for me to do it on mine since there wasn't a bolt or screw that I had to put through the tab. Just that plastic connector, which came out on both sides when I pulled the old ones out. Presumably if you did have to put the window hinge bolt through that hole in the tab you'd probably need to break it off, or at least cut a notch in the top to slide it around the bolt if you're not going to take apart your interior trim...
On the new trim did you just cut off that piece/tab before installing?
This has saved my rear cargo carpet from Sooo many stains. Weather it’s trays of food for a party, greasy parts from a LC that you are parting out or the bottom of a muddy cooler.
A HF canvas drop cloth is less than $10, water resistant, easily folded away or folded in half for the use of a third row seat! Best cheap mod in my truck by far.
4 Ft. x 12 Ft. Canvas Drop Cloth
Has anybody tried the door handle pockets on the rear doors? It looks like the rear door handle openings are a bit smaller, but maybe there's a chance they fit...? My kids could really use these back there as well....
ditto @Vlad and @Scat Adams my kit had all 4 too. In previous post (#308?) GIF is front other pix are rear. They work, kids LOVE them...
I ordered two kits off of ebay. They fit the rears doors perfect the front I'm not as pleased with.
i was thinking the same thing. A heat gun comes to mind. Funny, when i bought it, it only had the fronts!
did you buy from aliexpress ($18) or Amazon ($28)?
Ali $18 here
cargo attic, $15
Xq0C6i-IG8_nJS5gdwfxyQjZB98Sl5rEfHjLg_Oct-l4b6hjcvQLFpdlRzLhYaCMuMbBTnhuEqfqX3lws6fN-vz3p_0k6gUPHmwQXmB684WTUjz6TjU40lzy1nW5Zyupep_5ujzEW3MqBiOjMTroXCJCfbRtm3IsjFo1vKsuQVxi7w5Lo71Qy5qjLkL5X6j4Z8XKau5Fs9wXoJpOt8ACliseHKGLc3UsN_sCwg_6YCcfu7l8wRFFoei46FZ324UegmIZoXeq5ZG9ic1XQP8I94LC_gX-Fx2VANzRvcdr5tJCT0SKKk12SPeJTdMPCdNEWwJDZYRgdp7sMqtgtGL701SMWh4JzgnX-BJSN4unixpkCnV8p8P5xJaY2s_ANKg4mvpNyWV-tiN56zRUDaUcX1UwWyuaTArecph-0iPqYdNCJhUHg_CD87acQIeOiGpjjbIeLHqTnGgE3MVTSXMslBqWvT_CIWjoQ0I0IORiE2F9dd4VCP-c190UpVaZbHBhTBQKItY6zK0EK96tq7AnQXn1Uzx-2xseslUBbAp4084nbpVqObohnevQO0EbAAI8KPvnNTQdM_dSDSL_7z3yc7C-D4iCl1UQlg3w1TRkpoFBvo-iHmyu_rQKAGL-pUsP=w835-h626-no
weu8LOTZUT9HUmj2f32herSuXClqsVE8Y55WkuuwC4SGrVMRBiMcAnHgJ1VMav_61zxB8crb_z8h3QClHRAu8juLv5w5S3MQABUZ0kM2ESr_mQ7ALZiI6Z9_go3fNOYqRWWnb8CKtfSAtlb70sIuX2Vrf2k7uqlaY8WxfmA1KX0T5PbgkTepsgA5BfcdIhuepjWcrQMtCLw6-U3Ywrv7uBDMYl5Dz-pBM_f3g_gLtc9vZWocIZNGMUUkQiSDOZF6x0NBL8ublbnZV5gQI2F1gtTC1l5_zqlaV3vEh1miSoZCdH0IQFRBCu7BHvmElMCRIR_7b1vA518hHqhr-Py7BdYp7IK182P4AumiWKNgswRCWLyVpYF4otV3SwTZWKhBkAFl6_Clxp9CIk47j5_zAc161gTG0cmiq5HNiYmoWecAfdl1uZ062GEm3AE2Jh2PdrAomv545jgmF1tsPTBWw7sYEv0RF5Z7Yrkej2CmG0nvaq3eX_CbD1i6-eRbT3OGhxGlPNXg3lVYnDYtqNh4GCyEMMbwp5OWAR_rjrLbgnDhq1efD77nFaW5_ohJYwoFdOdlsGrdnqZGO_78LBa29O0qsOhVDVywr9ZSq7wSPXbAM-PN1B2DbcBsQdH8IG5m=w835-h626-no
6FE-DIO98yhavV9wrrLra9w1FQiNe7BMtYAxxuYvUQ3iS3u4Gb0ITYnms0ky-o8VTP-0D4AByTU83rcGn_iOrasEHDGN91ZAzTbMu1ng1lj4-Eh5P5ARqqvAW-Ho_SyOGuPNd3i3Lzfl0gus21dj4Y7x5HKmsuYrL9tiZP5YFVG4FgFSFzopLRkj1gmWn-puQ1O7cI5QeGkGVtz2etKj7OYUN18p-mF-I3c_abK36b63U2vQFi9JRCVHK_It0M7ySWh4P4xL5xbEkiOVFyDCE8k6mJUsq4tPfAmoVqlimPKWt9sEqeT6aaMUjYGyBYzHpb839V_7gz1h_cRHcyJ8rY9h6_HFjoy-nqahTbeUZC0aQiGLKcW0Bpqh_vH1vTWkmi4-NHGSfDRxT3wZ9bD64fomJ1TkGCYEgHvE48wFdLrJQp-ezOI5v21a9wFBKjrlN-4-ykVfZMMmoMniwj69vOo7gW02m-6-wF3Fr_xQoadskWoy8HbDKPq47JEQeoWQkJQxklnmGez1D3hW2XjbQuhNa0Ox9XFxscfvQQPi8ggCPF0gUCBF4RdYDD8PVhB2qaJlYqB_7PBoX5y-WUCv2WjETYbYK4bR2CnQF2fMgVDALtEyevDJsiAtn2XX33ei=w470-h626-no
PlfqCxEKI3Tm7HAV2Ee6yGW70XVrAM7Rn6HG5N6w22wHNuMt9FvZLdgiN3QOxGqrawNLefq-TPJOMPbFmxoLR32XHSDnIC84Sn7mGxSkJEBYD7fFevYbQHh7cZJrefEbvV_Z3zOFw7sPGxTetpkf9-V2J93ie0PVRIGLnyoJjSccJVLjGF-sEb2n1aR92p6nwko9au8TTin1JEabLbBNL6fSvM1gk8s4KN6c0TXg9eKHpRLJyjJPUg9lUGztIwN6q9NZaH_dgHssyFAqu26T4PNrPbgjz_zvxFBTtyfA9UG0b5_sUnrLT7pQEZyAZ7jPWQC8dOpajD3jdbFe0CV6hkMh1Y5IsvMp72q2ocjB-NyUyjZ_nlx1JvGrvu19jZNJyI0V-DFWpJtFvVyn86s7w74miWakcksgNulaWDkSYkajGsIWy2ioD1rH71cBPogkWoN_upNjmdYTaZIYeo9yANfuHtPDZNbCipVLixcMywaQ_dFfQqPezO2M_2MyF5Q9CS4Y936hGI5q_XcZwaqb9Z7DelEU9f29mmsNTrrF6gE0HJThMrLbmYzPnYsk5xjPqi4aqD_uoi3NUny7FwClzCc7EKBqjZdcDvxADI7pedXk7aBlHWjsYmwObKyzwzWr=w835-h626-no
Burley mil surplus. Stout straps and spring-claps. 3 straps on one sidethree on other and one side has claps as well.
*EDIT*
Rear visibility's pretty good too, 3 jackets up there now...
vng4bZjR-4SUYuL0rVuDRH496DfJCQ4lWAXSS5lmi0bNKENVCETFMGAERFEtL7bB1c8jwUA2aXDkmiR_JIpIj2IUyzwLADeu9S5tFybsVL_cz_pd-75C8LlplpaKLWegBE9ogzyMJ7ao4SPhh_3NPq1r_4RdRzz9_CM0fR5k3Hli5eZiae99JEwzPpLPF7fvZYzUHTnMv5aFFqt8RKslURhoid1_cdJtDqh6lmfjLqIvWTA6eMmKhEjzp__QiYqt7NC1CxbUidoJr9qD3XflMldgGwr2YlruIt1kyhfEmyaZ4YtbuCss2M0DY0sTbjaoHx-dMwJineIhvQ056XyogaRJqfj6xDjgZn6iTStH-fVGW4lbdnOH4CSZ2Big1TEdK8_GCURN5LGRA8C-o_Q2-T2KuMov4ynRUY3x5kUqXu6OW2YusgLNw87BwP_2IZh98WROOZjg1Ztgy7cUSU0M_i-h8AHREc11I94Sd_RZ99JlGnRiSNEqjD50mAldPleAvemdbmLd7-sR4pxSRd71TSh-Zr77wk0ysJn9TZG4U7aX-XlB8A_gJWN-M7n8hh3ejJKpj1cGEtomUzBN6jVcWFORh2i45eAMFGQA3v_Ir2JAXhZBkwiK1148I2jm7z9C=w770-h577-no
Nice! Do you think you would be able to put another one toward the front? Or is that distance shorter?
@GXMac
The distance between driver handles and 2nd row handles is 5" greater than from 2nd row to 3rd row handles, so yeah you could probably put in another one, but it'd interfere with headroom and possibly sunroof opening. You could center it or position it against the 2nd row handles, so err aft but it could interfere with headroom.
Cheap mod for mounting a iPad 12.9 Pro on the dash. Cygnett Magnet mounts bought from Costco. Holds firm down the highway and over bumps.
Installed my Tacoma windshield squirters. Work great, much better than the stock GX ones
cargo attic, $15
cargo attic, $15
I like it where did you find it? I see one on a Army Surplus Warehouse for 14.95 and it is 21" X 30" is this the one you have? Your looks like it is larger. DO you have a link?
Thanks, yeah it's pretty good. I found it on Coleman's mil surplus, it is 1" cotton webbing and about 20x31ish. . . the buckled strap tails are like 27"
Here's the link: U.S. G.I. General Purpose Cargo Net
*Agree with you!
As a contractor, this is a must! Side bonus use the spill/leak resistant type for a few dollars more (these will save you even more from the inevitable spill).
