To my somewhat dated knowledge... In a somewhat random order.
All gasoline is the same when it leaves the main pump at the terminal. In the business it is commonly called, "87 no lead." There three or more pumps at the terminal, depending on local regulations. Each has a different blending stock.
The octane value has no relevance to the amount of combustive power present in the mixture.
Blending octane value (BOV) winds up being important. A 5,000 gallon truck may fill up 90% with "87 no lead" BOV 87 and 10% with EtOH (Ethyl Alcohol) BOV 108 (round numbers) resulting in a (9*87 + 108)/10 = 89 octane Ethanol blend.
Typically this mixing is done in the truck on it's way from the depot to the station. Slosh/difusion.
There are over 10,000 identifiable components within any pump acquired standard gasoline. The "Octane" rating is based on a bench sample of Ocatane and Heptane as a benchmark. You will never get this at the pump.
Between tar and methane there are thousands of possible hydrocarbon combinations, particularly if you start dealing with left & right handed molecules, etc... Acetylene is probably the most ideal power to weight. Because of this it is expensive and refined out of pump gas.
Pump gas is composed of materials that are not saleable by themselves. This resultant blend of junk is then 'adjusted' to fit automotive requirements by adding good stuff until the vat of leftovers / not-so-good stuff meets minimal federal & state requirements.
Octane is one measurement, vapor pressure is another, calories is yet another, then there is the distillation curve showing how much of the fuel evaporates at what rate when heated at a constant rate.... etc...
Oil companies don't like Ethanol primarily because it is not 'pipeline fungible.' It mixes with water and pulls the water with it. So, a 200 proof (100%) ethanol stream will come out the other end with the water it picked up along the way increasing volume and decreasing usability. Ethanol + water + gasoline = cloudy gas.
MTBE & ETBE have BOV in the 116 range. MTBE was removed due to some issues with leaky tanks and water tables. ETBE never fully took off.
YMMV...
YMMV...
