Beeping noise when key is turned off and removed. (1 Viewer)
Western Wonderland
Ok this is something new that just started happening about 4 days ago. It sounds like an alarm clock going off. When I turn off the cruiser (its a 93 by the way) and remove the key, the little alarm sounds. Only for about 10-15 seconds. The sound is coming from right above the driver side sun visor. It feels like there is a little box under the headliner. I don't know what caused this to start happening recently or what it means. It does turn off and doesn't seem to effect anything. I'm not really concerned just curious. Thanks in advance.
Sunroof in tilt position.
Thanks.
I just barely did a search, after I posted DUH!!!! I should have done that to begin with. Dumb newb mistake. But seriously thanks Idahodoug
Surprised I was the first to post on that one!!
DougM
Leave your sunroof in the tilted position and turn the key off, then open the door.
DougM
You've got to love the search function on this forum. Had the beeping and found the solution.
Thanks.
