Beefy TieRod and Drag Links for Hy-Steer FJ40 Saginaw
Crawlorado.com
Website
www.crawlorado.com
I have a Tie Rod and Drag link that was on my rig, They utilize GM 1 ton TRE's
This is Custom Threaded DOM, they are Drilled and Tapped and are about 1/4 wall
Here is a link to the tie rod ends you would need..
1-Ton Steering Upgrade: JcrOffroad, Inc.
I used these with a Saginaw PS Box and Trail Gear Hi Steer Arms..
you will need to have 4 holes reemed for the 1 ton's..
here is a link from when i installed everything 2 years ago :popcorn:
attachment.php
i paid $120 New.. I Guess ill Take $70 Shipped
This is what i broke this weekend (where the clamp is).. will you setup work? Also, what part of co are you in? Let me know, Thx Ray
I'm confused.. are u selling the ends or the links? you say links, but have a pic of the end? let me know..p.s. if they work..DIBBS!
I have a 76' fj40 with small pattern knuckle.
Isotel, I just saw this post. I am wondering if there is enough clearance between the hole of the drag link tre and the tie rod bar tre on the passenger side of the high steer arm or do I need to buy the link that you have with the hole for this to work. I have the trail gear arms as well.
