Cruiserdrew
On the way there
What exactly do you mean when you say housing?![]()
Dan-The "differential", technically, is the center part with all the little geary bits in it, and that spins in the housing. The "housing" in contrast, is the heavy iron thing that holds everything. The complete assembly is the "3rd member".( Not your favorite part of your anatomy like you thought
I believe the pinion is maked with a check depth (a shim size) and that gets you very close for pinion depth on an initial install. I totally agree that letting Sean do it for you will be best in the end. I'll be up in Reno in 5 weeks or so, and can haul down the parts if desired.
