Battery for 1991 Land Cruiser LJ78
Highlands Ranch, CO
I think it’s time to replace my two batteries. I am
Not sure if the batteries currently on the cruiser is the correct. They are smaller in size than the battery brackets. Do you know the correct size of the batts and what the CCA need to be? Thanks for the help
Not sure if it's the same for the LJ models, but all the 24V BJ and HDJ Landcruisers I've had take one type 27 and one type 27F batteries. They fit perfectly with the factory brackets. Only difference between a 27 and a 27F is that the terminals are reversed (mirror imaged). No idea on CCA--it's cold and dark outside so I'm not going to go out and look. lol...
I'm assuming since you have two batteries that your truck is 24V, BTW.
LJ78 is 12V; the batteries are in parallel.
