ARCHIVE Barnes 4WD Universal 3 Link Kit (1 Viewer)
All Kits ship with brackets pre-drilled to the correct bolt hole size and no extra cost!
This is the kit that has all the parts that we are always using in the shop for customers three links suspensions. Our kits are built to stand up to the abuse that rock crawlers, weekend warriors, and daily driven rigs see. This kit includes:
1 x Axle Link Mount Pair 10 Deg
1 x Frame Link Mount
1 x Adjustable Inner Frame Link Mount Pair 0 Deg
1 x Link Tower
1 x Outside Frame Panhard / Trackbar Mounting Bracket
1 x Offset Axle Panhard Bracket
1 x Chromoly 3/4 - 16 X 3/4" Heim RH
1 x Chromoly 3/4 - 16 X 3/4" Heim LH
2 x High Misalignment Spacer - 3/4" to 5/8" (pair)
1 x 3/4" - 16 Jam Nut RH
1 x 3/4" - 16 Jam Nut LH
1 x Tube Insert (3/4-16) 1" ID Tube RH
1 x Tube Insert (3/4-16) 1" ID Tube LH
3 x Chromoly 1 1/4"- 12 X 1" Heim RH
3 x Chromoly 1 1/4"- 12 X 1" Heim LH
6 x High Misalignment Spacer - 1" to 5/8" (pair)
3 x 1-1/4" - 12 Jam Nut RH
3 x 1-1/4" - 12 Jam Nut LH
3 x Tube Insert (1-1/4-12) 1 1/2" ID Tube RH
3 x Tube Insert (1-1/4-12) 1 1/2" ID Tube LH
Besides our Universal 3 link kit, we also offer a couple of different varieties of 3 and 4 link kits. Including single and double triangulated 4 link kits. Our kits also are available with Enduro Joints or Chromoly heims. If you have any questions about substitutions let us know and we will make sure the kit is perfect for your application!
Find all our 3 and 4 link suspensions HERE.
Congratulations to Chris May on his win this past weekend at the Dirt Riot race at Gray Rock in Olive Alabama. Chris is running our four link, three link and a ton of other parts. It is always great to see your products winning!
