ARCHIVE Barnes 4WD Ultra 100 Offset Axle Panhard Bracket
This is our idea of the correct way to make an Offset Panhard / Trackbar bracket, it seems like 3 out of 4 need to be on the leading edge of the axle for clearance issues. The center of the heim will be 6", 7" or 8" vertically from the center of the axle tube and 3.5" forward of the center of the axle tube. They are cut to a 3 1/4" axle tube radius so they can be made to fit any tube diameter. This bracket is made from 3/16" 100,000 min yield steel plate and bent perfectly so you don't have to play with the grinder to make them fit! You will also notice that the design of this bracket allows you to weld it together with T-welds instead of butt welds.This is just another way that we designed strength into the bracket. This bracket has two drain holes built in. These are setup for a mounting width of 2" and have 5/8" holes.
