ARCHIVE Barnes 4wd Flush Mount Lower Triangulated 4 Link Bracket
If you are looking to have a dual triangulated four link suspension then this is the bracket for your project. Our Flush Mount Lower Triangulated 4 Link Bracket is cut from ¼” A50 Plate and is made to take tons of abuse. What makes our bracket different from our completion is that our bracket does not hang down any lower than the tube that it is welded on and you do not have to drill out the holes for your bolts. This allows you to keep your flat belly and not have an anchor hanging down tight in the center of your rig! This bracket is cut so that it will self jig to a 2 5/8” mounting width and a 20 degree.
We will also drill them for three sizes of bolts:
9/16"
5/8"
3/4"
You can find them for $43.55 here:
These brackets are great for building a triangulated 4 link suspension off of a tube frame, or crossmember. You can find our Flush Mount Lower Triangulated 4 Link Bracket for $43.55 here.
The Barnes 4WD Flush Mount Lower Triangulated 4 Link Brackets are cut for 1.75" tube, and we offer 3 different bolt hole sizes for you to choose from. They are only $43.55, and are available here.
