Bad tranny
I have a 2000 LC and the tranny is starting to slip. Any quick fixes or do I need to replace. What is the best option for replacement?
Thanks!
2000 have a bad history of early failures. Sorry to say, but you are more than likely looking at a full replacement, around $3500.
Well, the usual check the fluid levels, drop the fluid in the pan and look for metal. Could be the torque converter, valve body, probably a few other things to check before a new box. Take it to a reputable shop in the area and have them take a look.
There are quite a few threads on the 2000 transmission woes, it's a small percentage of the 2000 trannies that had problems, but a large enough number to stick out as a problem compared to other years.
How many miles?
Sent from my iPhone using IH8MUD
More info on "slip", please. That is not the typical 2000 failure mode. The failure is typically a catasrophic and sudden failure - no more motion at all. Anyway, start with the recommendation to check fluid and pan. Where are you located? There are some Cruiser-friendly toyota dealers that can do much better on a reman'd R&R than your typical off-the-street price, sometimes a couple of K better, based on some outrageous quotes lately. Depends on where you are though.
This.
Not that you couldn't have a bad clutch pack, just haven't seen any other postings here on MUD. But that is not the 'standard' 2000 LC failure mode.
